- 402
- 402
- 342
- 2013-5-18
論壇出錯,發了短消息給管理員都沒回覆~
Discuz! info: MySQL Query Error
User:
Time: 2011-9-8 9:51pm
Script: /index.php
SQL: SELECT t.*, f.name FROM [Table]threads t, [Table]forums f where f.fid=t.fid AND f.fid not IN(26,27,37,38,39,42,44,49,56,57,) AND t.displayorder not IN(-1,-2) ORDER BY t.dateline DESC LIMIT 0, 10
Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND t.displayorder not IN(-1,-2) ORDER BY t.dateline DESC LIMIT 0, 10' at line 1
Errno.: 1064
Similar error report has been dispatched to administrator before.
到 http://faq.comsenz.com 搜索此错误的解决方案
短消息發出後,變成空白頁,出現以下文字:
<?xml version="1.0" encoding="UTF-8"?>
-<root>
<![CDATA[<li id="pm_1249" class="s_clear self"> <a name="pm_1249"></a> <a name="new"></a><a class="avatar"><img src="http://choidaniel.sclub.tw/uc_server/avatar.php?uid=3&size=small" /></a> <p> <span class="time right">2011-9-8 21:53</span> <cite class="new">崔</cite> </p> <div class="summary">我測試功能,試發短消息~請忽略</div> <span class="action topact"> <a href="pm.php?action=new&pmid=1249" onclick="floatwin('open_sendpm', this.href, 600, 410);return false;">轉發</a> </span> </li> ]]>
</root> |
